3520 cab squeak
/ 3520 cab squeak #1
jrutherford
Bronze Member
Central IL
3520 cab/6330P
Anybody have a cab "chirping" in their tractor - sounds like big bird riding along?
Assuming it is glass, don't know how to fix.... tips please.
/ 3520 cab squeak #2
:D Mine did it also. Its the door latch mechanism. Your doors are not tight enough. At least mine were not. I think when they adjust them at the factory, the rubber is new, and has never been compressed. Over the time it takes for the customer to get them, the rubber loosens up a bit, and you have to tighten the door. Its simple, you just move the gold latch rod in a bit. Move small amounts at a time. You could also put some vasaline on your rod:D The door latch rod....:rolleyes:
/ 3520 cab squeak
LOL!!! Needed a good laugh this morning!
I'LL DO BOTH!!:D
Thanks nmu98
/ 3520 cab squeak #4
It's normal... mine did it for quite some time when it was new too... I came to believe it was the seal gaskets breaking in also... it will go away.
/ 3520 cab squeak #5
Mine did it when new..found it to be the "newness" of the rubber on the glass...its not slippery so it chirps. Spray a little silicone lube on a rag and wipe down your seals....it will go away.
Or you can give it a little time to get dusty & dirty...that works too :D
/ 3520 cab squeak #6
Whamma jamma !!! Just turn up the volume on the CD player !!!:D
Squeek gone !:D:D
Metal Rooster Weather Vane (A66738)
Metal Rooster...
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2014 Chevrolet Impala Limited Sedan (A66738)
2014 Chevrolet...
2020 ISUZU NRR BOX TRUCK (A67714)
2020 ISUZU NRR BOX...
