3520: Anyone have FEL and front A-frame
   / 3520: Anyone have FEL and front A-frame #1
hpc
IN
'06 3520, '09 997 ZTR
Hi, All,
I have a 3520, open station, with 300CX FEL. Been thinking about
adding the rotary broom for light snow removal/finishing sweep, etc.
However, the required front A-frame mount looks to be a pain to add or
remove when you want to use the FEL or remove it to use the broom.
Anyone have experience at what's required, tools and time, to
unmount the FEL; mount whatever is required for the broom and vice
versa?
I'm no longer using the 72" MMM since we have a ZTR..in case someone
thinks about what might be mid-mounted.
Appreciate any and all assistance. I really wish Deere offered a video for
"I have a FEL attached and want to use the broom..and vice versa".
Cheers!
LDM
   / 3520: Anyone have FEL and front A-frame #2
LDM
I have a 3530 w/CAB and have the 300CX FEL, 72D MMM, and a 366 Blade with extensions. The dealer mounted the hardware. But as I recall during the orientation all I have to do is remove the FEL and attach the blade and two hyd lines to the valve and I am good to go. The tractor mounted "A" frame hardware stays on the machine while running the FEL and MMM (with the exception of a couple of arms).
Try this link as it appears to packed with info & pics
http://www.tractorbynet.com/forums/john-deere-buying-pricing/118871-366-frame-mounted-blade-4.html
I have not used my machine in winter yet so I cannot fully comment on the hookup.
Tony
thanks for the link. I was thinking it was going to be a couple of hours
or more to remove the A-frame or add it back on. Looks like a caveman
could do this.
Appreciate the help.
Cheers!
LDM
   / 3520: Anyone have FEL and front A-frame #4
could do this.
Cheers!
LDM
Yep, easy to add/remove A-frame. Just 3 pins on arms where they attach to the tractor - similar to rear 3PH. Have done it many times on my 3720 cab.
   / 3520: Anyone have FEL and front A-frame #5
Have it on my 3720 cab and its very easy to remove and put on.It takes about two minutes to do very easy
2010 Ford Transit Connect Cargo Van (A55788)
2010 Ford Transit...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
(10) 2" X 5" & 4" X 10' CHANNEL IRON (A54756)
(10) 2" X 5" & 4"...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2006 John Deere HPX Gator 4x4 Utility Cart (A55787)
2006 John Deere...
