3520 Air Filter Question
/ 3520 Air Filter Question #1
JD333
Maine
JD 3320
Hi Folks,
I just bought a 3520 w/ about 600 hrs on it. While I was doing some maintenance on my new toy, I noticed there was only the large air filter in the air filter housing. The tech manual states that there is a dual element, one inside the other. I verified this with a local 3120 owner. I contacted the hobby dealer that I purchased it from and he said that it was an option and that some JD tractors of that series did not have them. I find this pretty hard to believe. Can anyone help with some solid info on this statement? The intake port looked ok, but I'd like to know if this is something I should be concerned about. Not exactly off to a good start with a this large investment. Thanks a lot for the help.
Jake
/ 3520 Air Filter Question #2
There are two, a primary (RE68048) and a secondary (RE68049). Buy the missing one (or both and start with a known air filter system in place).
About $35 for the primary and $25 for the secondary.
You can verify by going to jdparts.com and putting your model JD in, then look on the alphabetical listing under "Air"
/ 3520 Air Filter Question #3
You need a new dealer and an inner filter ASAP.
2015 Bobcat E42 (A64126)
2015 Bobcat E42...
Case TV450B (A64126)
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
