3515h, bl150 and Summit diverter
   / 3515h, bl150 and Summit diverter #11
Is the BL150 made by Ansung like the BL20? It seems weird for them to use JIC on one model and something else on another.
I think your idea of mounting the diverter by the loader valve will be fine. There will be two lines running forward to the quick connects for the implement. With the diverter out on the loader torque tube you'd have two lines running forward from the loader valve to the diverter and then two more running back to the end of the hard line near the loader valve. That's how the Branson factory diverter I saw a picture of was set up. You could remove the hard line completely and just run hoses from the diverter to a tee and to the cylinders, but that's more work.
Im not sure who makes the loader, but I recall reading somewhere that the BL150 was just a rebranded name from an older series with some tweeks or something.
   / 3515h, bl150 and Summit diverter #13
If you can remove the tee's in the curl hard lines on the right hand side of the loader frame,
then using elbow fittings run 2 short hoses to the diverter valve and 2 short hoses from the straight thru ports of the diverter back to the curl lines with the tee reinstalled in the lines for the curl cylinders then your quick connects can either go directly into the diverter valve or short hoes to were you wish to mount the quick connects.
That is just one way to do it.
Your proposed way will work just fine also.
Heck I ran hoses from one of my rear remotes up to my loader mounted quick connects.
Well, I think I got the hard part done, now just need to install the electronics, tighten it all down and secure the lines
   / 3515h, bl150 and Summit diverter #15
Looks good.
Thank you. It actually looks better in person. Lol and like a jack ***, In my haste to test it all out, I forgot to put thread locker on and snug everything up, but it did all work, fountains of fluid and all. I'll disassemble and thread seal and snug all connections tomorrow.
   / 3515h, bl150 and Summit diverter #17
I'm sure the Coors Light had nothing to do with any of that. :)
Lol touche, but in my defense, 2 of the bottles were from working on it the night before, and I was using them as a rain gauge ;)
Moving some firewood with the 3515, tried to use the Wicked grapple, but maybe I need more practice to get it to work betterFB_IMG_1597453498263.jpg
   / 3515h, bl150 and Summit diverter #20
Looks like your copilot was on the job.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
(APPROX 50) 2" X 2" X 97" TUBING (A51247)
(APPROX 50) 2" X...
JCB 1110T SERIES II SKID STEER (A51246)
JCB 1110T SERIES...
