3510i Hydraulic Questions.........
   / 3510i Hydraulic Questions......... #1
Canuck_49
Tallahassee, FL
Branson 3510i
Hi - I originally posted this on the Zetor/Century/Branson forum and a very helpful member suggested I ask this forum as well. I don't know a lot about tractor hydraulics so please excuse a few dumb questions...... :confused:
Can rear hydraulics be added to a 3510i? Mine has a FEL and of course a 3pt hitch but I've started to think about uses for rear hydraulics. Is this an expensive add-on? Apparently it's not as expensive as I thought, but I'd like to hear other member's experiences.
Are extra hydraulics needed to use a grapple on the FEL instead of the bucket? Is this an expensive add-on as well? Apparently there are 2 options, but again, I'd like to hear what other members have done or suggest.
The 3pt hitch arms raise and lower fully with only a short movement of the control lever. Is there a way to adjust this so the full range of the control lever is used, not just the top 3 or 4 inches? Wouldn't that give me better depth control on my scraper blade for example? Still looking for input on this one......
   / 3510i Hydraulic Questions......... #2
To use a grapple, you could add a solenoid diverter valve and use the curl circuit.
This valve would use the hyd for the curl in the normal or non powered mode. When the solenoid is activated, the circuit flow is to the grapple, and your joystick lever will then control the grapple.
The switch for control could be a thumb switch on the lever handle.
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
Skid steer auger plate (A50322)
Skid steer auger...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
