DiskDoctr
Platinum Member
I posted this info as part of another reply, but thought it was important enough to expand upon and post directly. (Important enough to end my days as a lurker and finally register so I could share this info)
CAUTION: 3510HST ("Hydrostatic 3510") is *NOT* a 3510 with hydro drive. It is more of a 2810 with a larger engine. about 2 feet shorter, around 800 or so pounds lighter, uses smaller loader, about 900lbs less lift capacity, but adds mid-mount mower up to 72".
I almost made the 3510HST mistake, figuring $1k was good price to up to hydro, but luckily found out about the big downgrade in tractor.
BTW, "mistake" would only apply to my personal needs, as the smaller tractor would not be right for our uses.
This term is used to refer more to the model number confusion than any assertion as to the quality or suitability of the 3510HST. If this suits your needs, by all means check it out.
Just don't get confused by the model numbers, they are NOT the same tractor, or even close!
Hope this helps others avoid any confusion.
This site is a great resource. I've been reading for about a month now. Thanks!
-JC
-JC
