3510 vs 3510HST
/ 3510 vs 3510HST #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I went to a Manhidra dealer today and was able to see just the 3510 gear. While checking out the differences between the two models I found them to be almost two separate models.
Engine Gear: 3A165 35HP / HST: 3A165C-DY1 34HP
Steering pump output Gear: 3.57gpm / HST:4.60gpm
3Point Lift : Gear 7.87gm 2865 lbs / HST 6.40gmp 2080 lbs
Remote: Gear 1 standard / HST: none
PTO : Gear 540rpm & 1000rpm / HST 540 rpm
Mid PTO: Gear Not available / HST Optional
Length: Gear 139 / HST 114
Width : Gear 58 / HST 52
Weight: 3881 lbs / 3064
Looking at all the specs, the difference are far more than just the difference in transmission.
BTW, I am given a quote of 16.3K for the 3510 gear+ML112FEL. 3510HST is 17.5 with ML108H FEL. Are these prices good?
/ 3510 vs 3510HST #2
I know a dealer in greenwell srings,LA that can give a beter price than that. give him a call (225)654-9269
by the way didnt u just buy a tractor
/ 3510 vs 3510HST
Not yet, I am still shopping. Delay on permit to work on my land holds me up.
/ 3510 vs 3510HST #4
Ok i got you.i just bought my 2615 from this dealer give him a call he will fix you up.u are looking at about 100 miles from your location. i live just west of u 75 miles or so.
/ 3510 vs 3510HST
Sorry for taking your time guys, I shoulda done a more thorough search. Other TBNers have already pointed out the differences long ago.
/ 3510 vs 3510HST #6
Not a problem,
Mahindra has made it kind of confusing by having two 3510 tractors. You would expect the 3510HST to be the same as the 3510 but HST instead Shuttle. In fact the 3510HST is the same tractor as the 2310 HST and the 2810 HST. The HP is the only thing that is different.
Dave in NH
2810HST
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
Farmall Cub Tractor (A62613)
Farmall Cub...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
Bear Statue (A64127)
