Oil & Fuel 3505 transmission fluid level check
   / 3505 transmission fluid level check #1
Davebest
Mahindra 3505, Massey Ferguson 165, John Deere 5100E
I want to check the level of the transmission fluid in my 3505 DI and expected to find a plug on the side of the transmission case. I've only found two plugs, besides the fill/vent plug on top. Both are on the bottom of the case, one is in front, and the other is at the rear under the PTO. Shouldn't there be a plug in the side? Is the front plug the check plug? The manual is worthless as to the check plug location. It also calls out 7 gallons of fluid in the transmission, doesn't seem like 7 gallons will fit if the front bottom plug is the check plug.
2016 CATERPILLAR 962M LOADER (A51242)
2016 CATERPILLAR...
1274 (A50490)
1274 (A50490)
2016 Komatsu PC1250 Hydraulic Excavator (A50322)
2016 Komatsu...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2008 INGERSOLL RAND DD-16 SMOOTH DBL DRUM ROLLER (A51242)
2008 INGERSOLL...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
