Mowing 350 Sickle bar mower
   / 350 Sickle bar mower #11
I have a 350 with the knock-back mechanism tube tore up. If I had the bolt center to center measurements, I could easily replace the tube. Can anyone help out here? Thank you in advance
xrringone:confused:
Can you post a pic of what measurement you want?
   / 350 Sickle bar mower #12
In the really light areas getting the cut oats off of the sickle bar was hard. I wound up tilting the bar up so they would fall off the back. If I didn't they would lay on the bar and clog the teeth so the uncut oats would not make it to the cutters and just get pushed over. Down side was that I was loosing 3-4 inches of oat stock. Thicker areas I could keep it level and the oats would lay over and were heavy enough to stay were they fell.
Yes, thickness will help but another part of the equation is speed. If you travel 6 mph or more, the natural reaction will be to fall backwards off the cutter bar.
   / 350 Sickle bar mower #13
Take a look here --
John Deere - Parts Catalog
Sometimes the on-line parts catalog will detail the dimensions of the part in the description.
Good luck.
AKfish
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2012 VOLVO BL70B BACKHOE LOADER (A51406)
2012 VOLVO BL70B...
Mobile toilet with shower (A53424)
Mobile toilet with...
(4) UNUSED LANDHONOR PINS (A54757)
(4) UNUSED...
UNUSED SDLANCH SDLE18P EXCAVATOR (A54756)
UNUSED SDLANCH...
2016 Ford Transit 250 Cargo Van (A53422)
2016 Ford Transit...
