345 starter engaging when key is on run
/ 345 starter engaging when key is on run #1
nateray11
Louisville, Ohio
John Deere 345
I have a 345 and the starter is engaging when I turn the key to the run position. I hear a buzzing from the circuit board located by the battery. I am wondering if I need to change that entire board or the ignition?
/ 345 starter engaging when key is on run #2
The switch is probably cheaper than the board. I think I would start there, but it might be two wires shorting together.
/ 345 starter engaging when key is on run #4
You actually get to buy both on these. ~ $125 as it comes as a set, but best bring your serial number.
