345 john deere water pump
/ 345 john deere water pump #1
Everettd
hubbardston
345 john deere
bolts are to long on water pump to remove with out raising engine. question i have to remove elec cluch but it will not drop after i remove bolt.
/ 345 john deere water pump #2
:welcome:
I'm going to move your thread over to the John Deere section to see if we can find you an answer.
/ 345 john deere water pump #3
Probably just rust/corrosion holding the PTO clutch on. The one on my JD 285 fell off when I removed the bolt to change the traction drive belt above it.
Zebrafive you were correct i use a puller and was able to slide it right off the shaft. Thanks for the help
2022 CHEVROLET GM515 SIVERADO 4X2 S/A FLATBED TRUCK (A67737)
2022 CHEVROLET...
12IN CENTRIFUGAL PUMP (A67714)
12IN CENTRIFUGAL...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
CAT 973 GP Bucket (A68134)
CAT 973 GP Bucket...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2023 JCB 90Z-2 T4 Midi Excavator (A66734)
2023 JCB 90Z-2 T4...
