345 Engine Problem
/ 345 Engine Problem #1
JDMainer
John Deere 345
I have a 345 with a 20 hp kaw engine. I ran out of gas the other day, since then it is only running on one cylinder. Already changed the plugs...what next?
/ 345 Engine Problem #2
How did you determine it is running on one cylinder? Running out of gas would not affect your spark. Do you think it is running rough because some dirt got sucked into the carb?
(3) STICKS OF 2" x 20' MILLING ROD (A63745)
(3) STICKS OF 2" x...
DBL SQUIRREL CAGE FAN ON ROLLING STAND (A63290)
DBL SQUIRREL CAGE...
2006 TerraGator 8104 (A63118)
2006 TerraGator...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
2716SFL (A61567)
2716SFL (A61567)
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
