Oil & Fuel 340B injection pump leak
   / 340B injection pump leak #1
ridger
ford 1700
this pump is leaking around the throttle valve shaft and the shut off valve shaft i repair most everything my self but i have not tried a injection pump sure could use some advice
thank yall anyway
   / 340B injection pump leak #3
there is a oring inside of the top cover of the pump and that is whats leaking. You have to remove the two nuts in the center of the top cover and remove the top cover. Then u can remove the trottle contral linage that is on top of the pump it is held on with a little nut and the trottle shaft can be taped out the bottom of the housing
thanks alot, can this be done without removing the pump thanks
   / 340B injection pump leak #6
You can do it without removing the pump. But it is much easier to see what you are doing with the pump off, and much easier to knock crap off the intake manifold or somewhere else into the injection pump with it installed on the tractor. Removing the pump is simple and installing it properly is as well.
   / 340B injection pump leak #7
i would have to agree sense you really cant get it out of time like a sims pump
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2019 FORD E350 16FT BOX TRUCK (A58018)
2019 FORD E350...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2025 AGT MH12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MH12RX...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
19088 (A55758)
19088 (A55758)
