ok forgive me if this comparsion has been done...but could not find it doing a search.
Have a real hard time deciding on the 3400 vs the 4400. I am going to be doing some dirt road work...small 1 acre planting...have about 400 acres of brush hogging...smostly broom weeds..but will be hitting some 2 - 2 1/2 inch ceder trees and some good sized patches of cactus . For the front end loader work...we have a gravel pit for hauling gravel for the road...pretty packed rock if you ask me. I am not worried about lifting x amount...but I sure would like to use a heavy duty 6 foot cutter.
The 4400 standard shift is about 4k more including the FEL. Not sure either one will do the 6 foot cutter...but then I am not cutting 3 inch trees for acers on end... only once in while and I don't mind lifting the cutter a bit or putting the loader down to help things out. For the road work I plan in using a 5 foot box or the FEL.
Also on the tires...are the ind tires better than the ag tires for FEL work....mostly on hard rock.
thanks in advance
thanks in advance
