336D - Can see dangling extension spring through clutch inspection hole. What is it?
   / 336D - Can see dangling extension spring through clutch inspection hole. What is it? #1
777funk
Yanmar/336D
I bought this tractor with a clutch rusted to the flywheel. I sprayed it with diesel and transmission fluid mix and hit the edges with a large flat punch in different spots and got it free. But it still moves with the clutch in. After a while of driving it, i notice that theres a spring hanging. I imagine separation of halves is in my future... but what is the spring? It is an extension spring (not large diameter) with a hook on the end.
Sure does! And now the clutch does not disengage. EDIT: is that a pedal return spring? If so, no this is inside the inspection hole in the bellhousing. I can see it with the cover off. Probably should not operate it with it like this I'd guess???
It was a huge relief when I saw the clutch pop free (did disengage), but it still moved even with the clutch down. Now it's tight to the flywheel again and I'm guessing due to the spring whatever it is.
   / 336D - Can see dangling extension spring through clutch inspection hole. What is it? #4
Only springs up inside the bellhousing would almost have to be from one of four on the clutch disc. Guessing.....
   / 336D - Can see dangling extension spring through clutch inspection hole. What is it? #5
No, the spring I attached is in the bell housing. It is the return spring for the clutch throw out bearing carrier.
   / 336D - Can see dangling extension spring through clutch inspection hole. What is it? #6
:thumbsup: and there's enough room to get your hand up in there..?
   / 336D - Can see dangling extension spring through clutch inspection hole. What is it? #7
Talking about attaching the drawing of the spring to this forum. :D
So I would assume I shouldn't use the tractor until that spring is back in tension?
I have some gravel to spread, but wouldn't want to damage the flywheel or other parts. I would think splitting the tractor will take me a full day since I've never done it before and it's 4wd.
   / 336D - Can see dangling extension spring through clutch inspection hole. What is it? #9
When you do please give us a writeup with lots of pictures.
2015 Chevrolet 3500 HD (A50120)
2015 Chevrolet...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50323)
2017 Big Tex 10ET...
New Paladin Tag Quick Coupler (A50774)
New Paladin Tag...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
