Dirt Moving 336 trans lever
/ 336 trans lever #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
There is a small lever behind the trans shifter handle, Wondered what this lever controls,its small and j shaped and on the cover behind the shifter,not on the column-
/ 336 trans lever #2
I don't know the answer so I'll ask you a question. Could it possibly be the lever that allows you to put it into creep gear? You may not even have a creep gear, just pondering.
/ 336 trans lever #3
Its the creep gear lock out I think.
To find out move it and try to shift the trans into I think next to first gear, there will be another slot.
My 3810 has it and I think these are similar. I just checked mine and it is next to first gear fyi.
/ 336 trans lever #4
Its greep gear access, it has to be moved to allow the trans shift lever to activate it
/ 336 trans lever
I thought it might be related as its very hard to get the tractor to go into low,Thanks for the reply-2,3,4 seem to shift fine and alot easier to engage
/ 336 trans lever #6
Do you mean creep low is hard to get into or 1st gear?
I have found that also if so and sometimes if you put the trans in creep low it is hard to get out of gear sometimes and you have to let the clutch out and roll the tractor while moving the shifter out of creep if that makes any sense?
Its such a low gear most of us have never found a use but still better to have more gears than not enough I say. :thumbsup:
/ 336 trans lever #7
I remember someone saying he used creep gear when wanting to see the seasons change while putting it in the barn.:D
/ 336 trans lever
We haad some Allis farm tractors years ago that had a very low first gear, used to set myb rother up there while baleing hay and had to wait for him at the next bale......The yanmar makes that look fast, its a very, very slow gear
/ 336 trans lever #9
I wish these had a road gear that's my only complaint I sure like the low gears but...
Mine will go about 9 mph flat out and I have roaded it 8-9 mile on dirt roads before and you can sure see and feel the weather change doing that! :D
/ 336 trans lever
mine seems to go pretty good in high ,not sure the speed but its o.k.....i try to keep the road miles to a minimum
/ 336 trans lever #11
I have a 336D but it is really old ( the serial number is in th low 200's so it has the power shift right by the gear shift lever).Sorry that I can;t help you.
/ 336 trans lever #12
Yeah me too except in that case it was hard to drive a truck with trailer full of firewood with 2 people and a tractor and make one trip out of it at dusk and plus that's how far I was from the shelter belt I was cutting at to home. :D
Nice way to see the countryside though take a nice slow AG tour on your tractor! :thumbsup:
Club Car Turf Carryall 252 (A64912)
Club Car Turf...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
John Deere 4630 (A64911)
John Deere 4630...
2011 Kubota ZD326 (A64912)
2011 Kubota ZD326...
1996 John Deere 7700 (A64911)
1996 John Deere...
