336 baler questions
/ 336 baler questions #21
??????????.png ??????????1.png ??????????2.png Here such nodes turn out
/ 336 baler questions #23
Do you have twine tension set according to the operators manual spec's?
/ 336 baler questions #24
Hi! Already I found the reason, now I want to find
where it is possible to buy good spare parts
on a press JD 336 sorter?
/ 336 baler questions #25
I just bought a JD 336 baler from a consignment auction. After I got it home, I found the data plate missing. Is there any way to ballpark the age of the baler? 2. One side will tie a knot but the other side does not. I'm kind of green when it comes to working on them and any help would be a great help. I would like to use it a bale straw this year. I don't have much time to get this baler field ready.
Hi! Don't prompt to me where it is possible to buy good details
on JD 336 press?
/ 336 baler questions #26
Welcome to TBN, RCCB. The 336 is a very good baler. Get an owner's manual and the technical repair manual. I bought the OM and the repair CD on eBay.
I'm not sure that investing a whole lot of time on the age of the baler is necessary... They're old! But, there's lots of parts and rebuild items available.
AKfish
on JD 336 press?
/ 336 baler questions #27
Very good baler. No significant changes to the current models. Parts catalog is on John Deere site on line. My dealer stocks most of the parts. Owners manual is a must. It tells you how to set up the knotters and everthing else. Knotters can be tricky though so if it still doesn't tie after you get it all to spec you may need some expert help to lay hands on it. The exact year is totally immaterial. Think 1980's.
FYI don't switch twine type. If you found any twine in the baler make sure you use the same material and weight as was previously used. There are places where the twine runs that wear and changing to another kind will fuzz the twine and give all kinds of problems.
on JD 336 press?
/ 336 baler questions #28
Old balers that have knotter problems can be a real pain to get running correctly. You need to debug the knotter problem and keep posting back here to TBN as you accumulate more data on the bad knotter so we can help you along. You can do some of the diagnostics without powering up the baler. But eventually, you're going to have to split apart 8-10 small square bales, hook the baler to your tractor and run it while you hand feed hay into the pickup and watch the knotter's perform. You need to get the operator, service and parts manuals pronto.
BTW: my baler is an old Massey Ferguson 124 (1960s vintage). I bought it right out of the field from the previous owner who used it the day before to bale about 30 acres and was "upgrading" to a JD336.
Good luck.
on JD 336 press?
/ 336 baler questions #29
On the side that is not tying, is there a knot on one end of the twine? If so, which end? The string on top of the bale or the string being brought up by the needle? What type of twine are you using? Sisal or plastic? 7000 or 9000 ft?
on JD 336 press?
/ 336 baler questions #30
336 was built through the 70's, not really into the 80's but some would have been sold new off dealer lots in the 80's.
on JD 336 press?
/ 336 baler questions #31
The 336 were good balers, we owned one back in the early 80's. When working on the knotters you can also clean out the bale chamber, then reach down between the divider and pull the twine up through hole.
Pull enough through so that you can get a good grip. Hold some back pressure against the twine and have someone turn the flywheel over by hand (trip the lever to engage the knotters). This helps if you are working on it in the shop or don't what to mess with feeding hay into it, this also helps to slow down the process which sometimes helps to find the problem.
You can do both knotters, but most of the time I will cut the twine on the working one and just do the problem one.
on JD 336 press?
/ 336 baler questions #33
vovhick
Here's the info and photo you PM'd me about. Register online at JDparts.com for a JD dealer of your choice
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
2002 John Deere 4510 (A64126)
2002 John Deere...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
