335 chain and chainsaw holder
   / 335 chain and chainsaw holder #1
tornadowatchranch
NE Kansas
Bobcat 335 for the fun stuff JD gt235 for the lawn
I cobbled these together on my day off. It is 4 inch pressure rated PVC for the chain holder. The short is 14 inches and used for tools of the day. The tall is 18 inches and holds one HF 3/8 chain. I was tired of putting them on the floorboards. The left (brake) side I had to move out so the short one hangs over--I will get a cap for the bottom in the future
The chainsaw holder used the loader support on the old style loader. I have included a pic of the other side. I used washers to space the 2x6s the correct distance apart. I only have a stihl 017 with a 14 inch bar so this works well for me. Paint is for the future(maybe).
   / 335 chain and chainsaw holder #2
Merely a suggestion (I need to make a chain holder -- good idea). The bar covers are fairly cheap -- put one between the 2x6's? Or, just rip out a slot in one of them and bolt them back together. Protect the blade from hitting the washers that way.
I love it! Now that you mention it there is a bar cover somewhere in the barn that came with the saw. Thanks.
cold and windy here so a good day to work in the barn--I already put your idea to work. Thanks again. Also added the grate to the bottom of the overhanging pipe. This was meant for a french drain and is not tight to the pipe but it is tight to the floorboard so should work well.
Thanks for looking
   / 335 chain and chainsaw holder #5
Are there holes to use on the back of the loader upright? or did you have to drill to mount the saw holder?
That's a nice simple way to carry a saw. A little white paint would finsh it off nicely.
first post pic #4 shows the hole on the other side. I only used one carraige bolt. It is pretty tight. If it tries to rotate I will go to plan B
   / 335 chain and chainsaw holder #7
While moving some snow tonight, I decided that I need more light out front. Now I am thinking about crafting a combo saw mount/light bracket on each side.
This forum is full of good ideas.
   / 335 chain and chainsaw holder #8
In place of the washers for spacers, I just sandwiched two strips of wood to space the gap. Then the chainsaw teeth will stay sharp longer.
What I did...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
J-BAR 4' ROATRY MOWER (A52708)
J-BAR 4' ROATRY...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
Kubota RTV-X900 Utility Cart (A56857)
Kubota RTV-X900...
