3341 with 102 loader not lifting
/ 3341 with 102 loader not lifting #1
missourian
just bought 3341 super with 102 loader purchased bulk feed in 2000 lb bag and loader would lift this bag. what is th max capacity or is something wrong with my new tractor and loader?
/ 3341 with 102 loader not lifting #2
102 at pivots = 3000 #, at 31.5" ahead of pivots 2100 #
breakout force = 5330 #, 3700 #
Hydraulic pump pressure is 2900 PSI, lift time is 4.5 seconds.
Spec wise it should lift the load effortlessly unless your pallet forks are seriously heavy duty.
/ 3341 with 102 loader not lifting #3
Are you running operating RPM? to lift load.
Jim
Thanks for response. Was runing tractor at max rpm and had chain hooked onto bucket. Would pallet forks or bale spear make that big of a difference?
/ 3341 with 102 loader not lifting #5
Pressure relief valve setting in loader lift vale may not be set right.
Go to www.zetorna.com and there is a forum where you can ask technical questions.
Chuck
/ 3341 with 102 loader not lifting #6
Always remember this, the further the weight forward is, the more it will weigh.
Its kinda like holding a 5 gallon bucket of water under your shoulder and holding the same bucket at arms length.
Ya know what I mean?
Jim
/ 3341 with 102 loader not lifting #7
I agree the weight is levered if the pallet is chained in front of the bucket.
My tractor lifted this at about 1200 rpm easily on a ball out at the tip of 42" pallet forks. It is a 2K trailer + probably 3K old buick headed for the junkyard. I lifted it high enough to rotate on the rear trailer axle to minimize tire skid marks when turning on a concrete driveway.
Can you hear the pressure relief venting when you try lifting?
barryinmn can u resend photo. it will not come thru for some reason. will be back at house on 8-7 and will check all these things out. will also take back to dealer to try to get him to go back over it. thanks again for responses.
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2013 BMW X28I AWD SUV (A61574)
2013 BMW X28I AWD...
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2016 Nissan Altima Sedan. (A61574)
2016 Nissan Altima...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
