3320 wheel bolt size?
/ 3320 wheel bolt size? #1
anojones
WA
JD 3320
Hey- does anyone know the wheel bolt size for the front on a JD 30 twenty series? None of my sockets fit and I have a front flat to get fixed. I did a search but can't seem to come up with the answer. Thanks for any help.
/ 3320 wheel bolt size? #2
I suspect you know they are metric, for starters.
What sockets did 'not fit' and which metric size was 'too big' and which 'too small' ?? Or, if you just have standard (for US) sizes, which ones were too big and which too small?
/ 3320 wheel bolt size? #3
22 mm. A 7/8 (22.225 mm) is just a little too big. In a pinch a 7/8 six sided socket could be used but you should go get the metric 22 mm socket.
Thanks for the info- I had a 24mm and a 20mm and wan't sure which of the three in between it would be. Thanks again.
