3320 w/ H165 Loader Lowers When Curling
   / 3320 w/ H165 Loader Lowers When Curling #1
Hoopman5000
Hi all, I recently took delivery of a new 3320 with the H165 loader, with a set of forks. When I go to curl back, feathering the control valve, the load drops. If I shift the valve further, the load will then start to lift. Weight on the pallet was approx 600 lbs, Engine rpm was 1900.
I've been reading a lot on the 1 series with this exact problem but didn't see anything with the 3 series. The fix for the 1 series was a redesigned valve.
Has anyone here with a 3 series seen this issue?
Thanks!
   / 3320 w/ H165 Loader Lowers When Curling #2
If the lift spool is in neutral, that should not happen.
Are you sure you are not pushing just a little on the lift spool.
Try cycling through the hyd about 5 times to purge any air that might be in the cyl.
The load check holds the load while the spool is in neutral, but when I start to curl the load by feathering the valve, then the load starts to drop. If I shift the valve further to curl it will stop dropping and then begin to curl up
   / 3320 w/ H165 Loader Lowers When Curling #4
Is the loader dropping or are the forks tipping down before starting to raise?
The forks are tipping down, then I shift the curl valve more and it begins to curl up
   / 3320 w/ H165 Loader Lowers When Curling #6
I noticed on my new NH loader when I curl down to back drag if I'm not real careful when I raise or lower the bucket will uncurl and almost flop up. I blame it on operated error. There must not be much play on new joysticks. My old ones can move in a circle and the bucket doesn't move.
   / 3320 w/ H165 Loader Lowers When Curling #7
Remove the load check valve and inspect and clean.
Check poppet, spring and seat.
   / 3320 w/ H165 Loader Lowers When Curling #8
Make certain your hoses are connected correctly at the quick disconnects. The FEL valve has a float on the raise/lower and a quick dump on the bucket. Perhaps you have something plugged up wrong.
1274 (A50490)
1274 (A50490)
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
(2) John Deere Front Fenders (A50121)
(2) John Deere...
2018 Ford F-150 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
