3320 Tiller size
   / 3320 Tiller size #1
Duckklr69
Hammond NY
JD 3320
Hey everyone, I'm looking for a little advice, I have a 3320 and I am looking at rotary tillers, specifically CCM tillers, first off do you think the 3320 will handle a 60' tiller? I live in upstate NY, we have clay and some rock, second the models I'm looking at are the CR60 and the MR160, CR weighs 460lbs the MR 630lbs. so what do you think?
   / 3320 Tiller size #2
Duckklr69:
Welcome to TBN :D! I live in an area where the soil is similar to yours. I have a CCM MR-160 and I have no complaints about it. I will also add that CCM's suppport and responsiveness is without equal :D! Your 3320 has slightly more HP than my
"29", you should not have any problems with the MR-160. Just get a tiller wider than your tire width. Jay
   / 3320 Tiller size #3
Duck,
I have a 52" Woods I use on my 3320 (originally bought it for a 24 HP tractor). I have to offset it to cover the tire tracks. There is no doubt in my mind that the 3320 will EASILY handle a 60" tiller.
Sorry, I don't have any experience with CCM.
KB
   / 3320 Tiller size #4
Hey Duck, I have the 5' King Kutter and my JD 2520 handles it fine. Before the 2520 I had a 2210 and it worked the snot out of it! I would think a 3320 would play with a 5' tiller. Soil around here is clay and black dirt. Also my tiller weighs 700lbs. I dont need front end weight at all, and the heavier the tiller the better in my opnion.
Dennis
   / 3320 Tiller size #5
I have a 57" Frontier and it just covers the tire tracks on my 3720.
My Father uses the same tiller on his 4110... thats around 20HP...
I would think you could run a 80" tiller off your 3320..... with ease..... even in heavy ground....
   / 3320 Tiller size #6
The 3320 will handle the 60" just fine. As a matter of fact, John Deere lists the 665 tiller (which is 65") as a suitable implement for the 3320.
   / 3320 Tiller size #7
I would get a 66-72" model. Cost is minimally more and the tractor can handle it. Your tractor width is right at 59-60" and a 60" tiller is just going to cover. It is always much nicer to clear beyond the tires. I have a JD 3720 and did some extremely hard clay this spring which had heavy grass. Had to go very slow due to the tiller jumping on the hard ground. Tractor power was not the issue with my 72" KK tiller. Hit a metal gate buried in the ground. Gave the slip clutch on the tiller its first use. The tractor didn't hardly notice it. It took me a moment to realize what happened before I raised the tiller. I forgot the tiller had a slip clutch.
   / 3320 Tiller size #8
I've got the Frontier RT1160 on my 3120 and I've never had it struggle. You'll have to look it up but I think it is 59". It covers my tracks and I have the same tractor with 3 less hp.
   / 3320 Tiller size #9
I looked it up and it is 57". Everything I've done with it I know I could have gone much bigger.
   / 3320 Tiller size
Thanks for all your replies, so a 60' tiller is no problem for the 3320 and it will just cover my tracks, maybe I will go a little larger.
43022 (A51691)
43022 (A51691)
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
