Oil & Fuel 3320 Fuel Usage
   / 3320 Fuel Usage
ihookem said:
Killer B, I ran it straight for 3 hours but only put 2 hrs. on the tac at an average of about 1500 rpm. So it all depends on rpm.
This confirms my suspicion. It also means that a Deere 600 hours may only have worked as much as a Kub with 400 hours showing on the clock.
This really should be standardized.
   / 3320 Fuel Usage #13
KennedyDiesel said:
An hour meter measures time pure and simple. No reference to RPM...
On many older tractors, and some new ones, the hour meter is gear driven from the tachometer and synchronized to run at whatever engine speed equates to 540 RPM at the PTO.
So one hour at 540 RPM PTO speed will register one hour, but if the tractor is run at a reduced RPM then the hour meter will run slow also.
   / 3320 Fuel Usage
This also explains with the hours on my Deere seem to rack up quicker than they did on my Kubota.
   / 3320 Fuel Usage #15
I am not sure how the new Deere's work with all that electronic stuff, But I think your is a true hour meter.
I remember reading in the Kub forum about someone who had a BX, and his son turned the key on when no one was around...He was asking how to erase the extra 30 or so hours:eek:
Maybe the Deere is smart enough to not run unless the engine is actually running?
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
