Backhoe 3320 + 448 backhoe - first impressions
   / 3320 + 448 backhoe - first impressions #1
Nathan_OR
I took delivery of the 448 backhoe with 18" HD bucket last night and had a few hours to play around with it. I'm a complete newbie to backhoes so bear that in mind when reading... this info probably isn't useful to any of you experts out there.
Pros:
- plenty of power even at low engine RPMs... I pulled out a boulder that has been plaguing my lawn mower for years, probably 3' across with only a few inches sticking out above the surface, and the hoe just hooked it and pulled it right out... amazing how much the earth heaved up around it... lots of power! kinda scary actually :)
- easier to get going with the thing than I had feared, probably because I kept the engine at ~1400 RPMs, which meant that it wasn't too quick or jerky... still it was hard to get "down" (see below)
- everything that swivels has a grease fitting! this thing should last forever if maintained properly
- the seat mechanism is sweet, I can step out of the backhoe operator's chair onto my tire (holding onto the ROPS) flip up the hoe seat, drop the tractor seat, and step into the tractor seat in just a few seconds... then back in just about as little time (although it takes a second to flip down the bh operator's seat because it has a catch you have to reach for)
Cons:
- taking the thing on and off is a bit of a chore. I'm sure I'll quicker at it but just getting the thing lined up is a real PITA, since you not only have to be square to the thing side-to-side, but the hoe frame bracket has to be tilted properly to hook it with the 3ph pins... once I get fast at it I imagine I'll be able to put it on in ~20 minutes (and about the same for taking it off and putting back on the 3ph arms) but it's never going to be something you want to just throw on to do a quick job then take off
- the ROPS really has to be up to use it, it's just too powerful with too much leverage on the tractor to risk otherwise, and this means that for me I'm going to have to take it off to fit in my parking spot... bummer, won't bug most people but if you have to fold down your ROPS to fit into your shed, you will have to fold/unfold any time you use it
- its a lot harder to master than other implements I've used... the boxblade I got working smoothly and quickly in a few hours of practice... cutting a flat bottom with the hoe is so far pretty hard, since as you bring the arm back toward yourself the angle of the bucket has to change to keep level with the ground... excavator joysticks are a lot more intuitive, at least for me
Other:
- with the hoe on, my tractor officially feels HEAVY. I bet I'm weighing in around 6000lbs. This is great for digging with the loader but it also left 2-3" deep ruts in ground that was supporting the tractor okay with the hoe off.
Overall the thing seems like a great (even necessary) tool for some jobs I have lined up. Pulling stumps, digging french drains or irrigation pipelines, digging up old foundation footing, and putting in a new septic tank. However I think that I had some ideas for it that really won't be practical: carving out dirt for a new walkway (better to use the boxblade), pulling out fenceposts (loader and chain does the trick much quicker since I don't have to set up the outriggers at every post), and other stuff that doesn't involve deep digging seems like the overhead of detaching the 3ph, attaching the hoe, and then setting up the hoe everywhere I want to work, will mean that the hoe doesn't get used for as many "odd jobs" as I had thought when I plunked down the $8k for it.
Anyway just thought I'd share my newbie thoughts on the thing... I'll update as I learn more of the ins and outs ;)
Nathan
   / 3320 + 448 backhoe - first impressions #2
Try raising the backhoe in to position with the stabilizers...the holes will line-up more easily.
   / 3320 + 448 backhoe - first impressions #3
Here are a couple of non-prescribed tips:
Eventually you're going to slip off your rear tire when climbing around on it, probably some day when it's wet or muddy ...try using a half-raised stabilizer as a step.
   / 3320 + 448 backhoe - first impressions #4
A couple of things I have gleaned from here, and things I had to learn the hard way:
The manual says curl the bucket part way when dismounting the BH. From experience the hydralulics leak down leaving the BH leaned too far back. Two methods to help. dump the bucket all the way, or curl the bucket all the way and have cribbing to park it on.
I used extension hoses from the rear grease ports on the swing cylinders to make it easier to grease those pivots.
I think the dismounted bh is too unstable as is. The kids know they are not supposed to play on/ around the tools. But kids... I lower the stabilizers to just clear the ground when the BH is lowered to the ground.
You WILL find the one pipe no one knows about.
Have a spare tooth
I have the time down to about 7 minutes to mount the BH and 10 to dismount. Practice and a good system. While I do try to have projects lined up, I find it takes more time to stage scheduling of tasks than it does to mount/ dismount the bh.
have fun
   / 3320 + 448 backhoe - first impressions #5
Everything about mounting and dismounting the backhoe gets easier if you have a level concrete pad to park it on.
I have had the same experience as CiderTom. That is, the OM says to adjust the bucket so that the edge is parallel with the ground when parking. That works like a charm to take it off, but if it is more than a day or two before you put it back on, the hydraulics leak off and the angle is all wrong. Lifting with the stabilizers means swapping the hoses an extra time, too. What I did is cut a scrap 2 x 4 that fits from the bottom of the bucket to the joint in the boom (48-1/2" for a 48BH). When I park it, I put the 2 x 4 in place and curl the bucket up to it (gently). Now it will stay at exactly the right angle for remounting.
Before my 2 x 4 trick, it would take me 3 or 4 tries to get lined up and snag the hooks with the rock shaft. Now I get it on the first or second try every time. Keep practicing. After a couple of times you'll get it down to the point you will look for reasons to use your BH -- I do.
   / 3320 + 448 backhoe - first impressions #6
jeffinsgf - Great tip!
I'm removing my 448 for the first time this weekend, so, this is timely. Thanks
   / 3320 + 448 backhoe - first impressions #7
I still say you'll find that raising the backhoe in to place on the tractor with the stabilizers to be the quickest way to complete the task. There's no need to use the rockshaft; leave it in the lowest position. An other advantage in using just the stabilizers is that you don't have to worry about the leak-down that every one is talking about; just adjust the stabilizers to level and align the hoe.
   / 3320 + 448 backhoe - first impressions #8
I'll have to try it your way sometime, Dave. I have always used the rock shaft because that is how it says to do it in the manual. I also don't have room to swing the stabilizers down in the spot where my hoe is parked.
   / 3320 + 448 backhoe - first impressions #9
This is the best way I have found to store my loader and hoe. it is very stabile if you put 2 2x4s under the back of the hoe. I also put a strap on the stabilzers so they dont leak down. the angle is perfect to pick and drop, I only use the rockshaft to lift in place.
   / 3320 + 448 backhoe - first impressions #10
I started storing my 430 loader and 48BH for my 4410 that way as well. Takes up less space in the garage.
Craig
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
