3320 32.5hp vs 4120 43hp Tractors?
   / 3320 32.5hp vs 4120 43hp Tractors? #1
Ramairfreak98ss
Columbus, NJ
Ferris/Simplicity/John Deere
The 4000 series is 3700lbs base vs 2900lbs base for the 3320 model. Is the 4000 series that much better? I think i like the 3320/3520 models more since theyre not so large yet and have more attachments available for them.
   / 3320 32.5hp vs 4120 43hp Tractors? #2
It all depends on what you are going to use the tractor for. If you need a smaller machine to fit in tight quarters, the 3320 would be better. If you need to brush hog ten acres and need greater lift capacity from the front end loader, the 4120 would be the better machine.
What are you going to use the machine for?
Im using it for landscaping jobs, mostly loader work, post hole digging for potted plants like 24" diameter etc. Ill be using a tiller too like 55" on the 3320 but the 4000 ones need a 65" + tiller which is huge now. I did not see a 4120 in person so its hard to tell by the picture how large it is, by the guy sitting on it i think its more than im looking for, more money too.
   / 3320 32.5hp vs 4120 43hp Tractors? #4
I think a large frame would be too much for these needs. I have had both, most recently a 4520. To me, the large frames are much more machine than the mid frames. They do more, faster, and have a lot more power--BUT--there are times I miss my 3720. It was a really stout tractor, and I am now wondering whether to attempt to buy a RFM for spring with my new tractor, or to get something small for specifically mowing. The 3720 with a rear mower was the ticket, and did great. I think the 4000's are a smidge too heavy for treading lightly on grassy areas or in landscaped areas where the ground may be soft. They would do fine, the ground might not. In short, if you have big projects that require big power to complete, go large, if you primarily want something that can get around in tight spaces but still has enough weight to do heavier work, go with the mid frame. My neighbor cleared 7 acres of SOLID woods with his old 4410 (mid frame) and it did fine. He now has a 4320, and thinks it would have done it in half the time.
John M
   / 3320 32.5hp vs 4120 43hp Tractors? #5
Maybe this will help you: 3000 series engine: Yanmar made in Japan, 4000: JD powertech made in USA. Personally, I like spending my dollars on this side of the Pacific, thats the main reason I went with JD. Also of course their quality and performance is as good or better than any of the competion.
   / 3320 32.5hp vs 4120 43hp Tractors? #6
From the sounds of your needs or desires, the 3320/3520 would be the way to go, IMO, as this midframe size is very handy in and around buildings and bushes, etc. The size and power should not leave you short for a good working machine. If it is, then there is always the option to trade up and go with the ligger frame. I'd be surprised if you were not happy with the mid-frame. Hope this helps your decision, and look forward to how you like whatever decision you make. /forums/images/graemlins/wink.gif
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2006 International 9400i (A53472)
2006 International...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
