3320 300cx 448 weight?
/ 3320 300cx 448 weight? #1
KB9UDE
Platinum Member
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
Hello all
I am again thinking about a 3320, 300cx, and 448 bh. What should this setup weigh?? Would it be ok on a 7000lb trailer??
John
/ 3320 300cx 448 weight? #2
I have the identical set up and the answer is no. The tractor and FEL alone are almost up to the 5k the trailer can haul ( deduct the trailers weight to find load capacity) You hear it all the time on TBN safetly factor. If you add up all the unthought of stuff like fuel,chains,etc you'll often find that there you are at or exceeding the gvw if you cut it too close. Plus if you ever need to haul the tractor and say a few implements you'd be S.O.L.. Just my two cents. Oh the weights are 2900lbs dry for the tractor,I believe the loader is around 900lbs and the hoe weighs around 1500lbs. So you're already at 5300
without any fluids or chains and any other misc stuff you might need.
Matt T.:D
PORTA POTTY (A68842)
2017 Link-Belt 350X4 Hydraulic Excavator (A66734)
2017 Link-Belt...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
