3316 shuttle transmission oil leak
   / 3316 shuttle transmission oil leak #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
With the tractor parked in my shed I noticed a spot of oil on the floor . The tractor is leaking hydraulic oil . Not a big leak , just a few drops now and then and is leaking from the transmission I think it is called . The area on the left side above where the filter pipe goes into the transmission is wet . It is also leaking on the right side of the transmission but not as much . Both sides are wet and is not leaking enough to tell where it is comming from . Is there a place where I can get a service manual or a parts diagram of the area leaking ?
I cleaned the area on both sides with brake cleaner and a brush . I then wiped it clean with a piece of cloth . Several hours later I could see that the oil is coming out between the hub and transmission . I guess the gasket has failed or the bolts holding it together may be slack . The hub on the left side is leaking worse than the right side . Does anyone know what the torque settings is for the bolts ? Is it a big job to replace the gasket ?
   / 3316 shuttle transmission oil leak #3
Seal - tell me the size of the bolt and I can relate to you the torque.
Thanks arrow . I tried a 9/16 wrench on the bolt by the leak and it seems to fit ok . A 14 mm wrench also fit ok . The leaks are both on the front part of the hub with the left side leaking the most .
   / 3316 shuttle transmission oil leak #5
More than likely its a metric. 9/16 fits because 9/16 = 14.2 mm. Bolt heads vary in size slightly. A 14 mm standard 5D bolt will be 55 ft lbs. If its an 8G bolt, that's 89ft lbs. If its a 10K bolt, that's 117 ft lbs. The metrics have their grade stampings expressed as numbrs on the bolt head.
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
