Traction 3316 MFWD
/ 3316 MFWD #1
randall57
oklahoma
3316 mahindra
I just bought a 2011 3316 and just noticed when I was climing a sandy hill at an angle my right front wheel would not pull while the left front wheel would spin in the sand and the only way that I could get unstuck was to engage the rear differential. Any one have any suggestions on what might be wrong or does the front right wheel not turn also. Please give me some advice. Thanks
/ 3316 MFWD #4
If both wheels turned while you are making a turn, in forewheel drive you could not make sharp turns. One wheel needs to freewheel in a turn. Jim
/ 3316 MFWD #5
It is working properly.
+1 normal
every axle will do it unless it has a diff lock or limited slip diff
Your rear wheels were doing the same, until you engaged the diff lock which sends power to both wheels.
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
72" JCT TILLER (A62613)
72" JCT TILLER...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
2006 Shamrock 10ft. S/A Enlcosed K-9 Transport Trailer (A61574)
2006 Shamrock...
