331 Hydraulic lockout wont release
   / 331 Hydraulic lockout wont release #1
miketdesco
John Deere 3520, X744 & 332. Bobcat 331 Mini Ex
Hello. Ive lurked on here for many years and always found what I needed, but I am finally stumped.
I have a bobcat 331 mini excavator. We just had 14" of rain in a couple days and now all of a sudden I am having all kinds of problems. When I lower the left console, the light wont come on saying hydraulics are active and I don't have any controls. Earlier today, the light would flash on briefly but then go back off. Once it stayed on for about 2 minutes and everything worked fine. Is there a way to test the console sensor? Its got 3 wires to it (8v DC, ground and console comm). Earlier today, the light would flash on when I put the left console down or if I put a magnet to the sensor. Now, it wont do anything. I checked continuity to the right console and that all seems good, but the console was FULL of water. I dried that out now.
I've either got a bad sensor in the left console or a bad dash console on the right. One is $50, the other is $1000ish. Does anyone know how/if I can test that left console sensor?
Thanks.
   / 331 Hydraulic lockout wont release #2
Guessing your unit is an open cab ? Sounds like you may have water in one or more plugs. Is the display controller in good shape. Water tight? No way to test without laptop at dealer. :confused3:
   / 331 Hydraulic lockout wont release #3
:welcome:
To the TBN forum Mike. We are glad that you finally joined. Sorry that it is for a problem.
Yes. It is an open cab. I pulled the controller and it was full or water. I took it apart and dried it out real well and lubed all the plugs. I also checked continuity across all 3 wires that come from the console switch and that seemed good.
I致e tried testing the console switch but I can稚 find out how to test it痴 functionality. No mater what I do, I can稚 get continuity across any 2 terminals. I知 picking up a new console switch today and trying thay. I hate just trying parts that I haven稚 confirmed are bad, but I知 kind of stuck right now.
   / 331 Hydraulic lockout wont release #5
If your display controller had water in it its cooked! I'm talking about the display that has the temp and fuel gauge on it. Has 4 or 6 plugs on back. Its a sealed unit. :eek:
I tried the new switch and that didn稚 help. I guess that was a waste of $60.....
I have a lead on a used console, but if not, I guess I知 stuck spending $930 for a new one.
   / 331 Hydraulic lockout wont release #7
Beware of used!!! New or used it has to be programed at dealer.
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
RIGID TOOLBOX (A52472)
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
