322d groundsmaster with hanson general snowblower.
   / 322d groundsmaster with hanson general snowblower. #1
hartwa
WI
jd260 skid steer
Hoping someone might know what i need here.
This is a shaft driven snowblower on a 322d groundsmaster. I just got it have not used it yet. i noticed the blower spins freely and opened up the gear box. Looks like the 2 disc were connected with a shear pin that broke loose. One has a 1/4 hole and the other a slot...although it looks like the slot was cut into it or broken away.
Does anyone know a shear i should put in here...may i can use a #2 bolt?
Thanks for any help.
   / 322d groundsmaster with hanson general snowblower. #2
The manual or parts diagram should show that.
I have used that style of snowblower on nice flat sidewalks and let me tell you they suck. You can either blow or steer. When the blower is up the steer wheels loose weight. When the blower is down you loose traction. Yes it had a rear weight and wheel weights.
I cant find the parts diagram anywhere. For the steering....they just need a lot of weight.
   / 322d groundsmaster with hanson general snowblower. #4
Suspect would be grade 5 since grade 2 smears real bad when they shear.
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2019 POLARIS RANGER XP1000 RTV (A51406)
2019 POLARIS...
