322 Charge Light On
/ 322 Charge Light On #1
Kaw235
John Deere 322
My 322 charge light comes on dimly while running both in idle and full speed. All voltage checks per the manual are fine both A/C and D C at the regulator as well as at the battery. I replaced the voltage regulator, battery and ignition switch. The charge light goes out when I turn the headlights on. I am thinking there is a short in the light circuit?
Troubleshooting per TM and find it cranks and starts while in forward or reverse. the switch tests ok so per TM it is relay ground. I will try to follow the wiring back to test. The problem started when I burned up the regulator, even burned out one of the regulator lugs and much of the first 4 inches of wire coming out of the regulator.
2250' of 5" Tile (A66408)
2250' of 5" Tile...
John Deere 13ft. Disc (A65640)
John Deere 13ft...
3IN TRANSFER PUMP (A65643)
3IN TRANSFER PUMP...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2013 FORD F-550 SUPER DUTY (A65643)
2013 FORD F-550...
2022 EZ-GO ELITE...
