3215 starting problems
/ 3215 starting problems #1
paulssigns
tym 400
hi.i have a 3215 tlb.400 hours.the starting problem.when turning to the start pos.just clicks.click enough then it will start.had the starter checked.its o.k.when it clicks low voltage at the starter replaced the key switch,no change.found a bank of small relays under the dash.saw one arcing when the starter clicks,replaced it no change.all grounds are good.any ideas?i can't find a wiring diagram unless i order a repair manual.$125.
/ 3215 starting problems #2
I'd say a bad connection, probably a ground even though you have checked them. You have ruled out the ignition switch and starter. Generally a safety switch is a go or no go, not a low voltage situation, but you could bypass each one, one at a time, and make sure that isn't an issue. Of course anytime you do any safety switch bypass testing, you must be super careful or you could hurt or kill yourself. Had to add that disclaimer, you can't be too careful.
Repair manuals are expensive, I wish Mahindra would just post them as free PDF files. As a dealer, I cringe every time I tell people they are $125. For the little we make on a manual, its not worth dealing with the "cringe". ;)
/ 3215 starting problems #3
We had one a few years back and it was a bad safety switch. Check voltages at each switch, you should see 12v on each side of the switch when holding key in start position. The bad one had about 6V coming out.
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
Mini rock grapples (A61567)
Mini rock grapples...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
