3215 HST
/ 3215 HST #1
Boit
Is it an indication that the hydraulic fluid and filter(s) need changing when the tractor seems to lose strength in the backhoe/FEL plus its hill climbing ability is weakening as well? The tractor was bought new in october '07 and has about 76 hrs. and no hydraulic attention at all. My theory is that since it was new, that break-in crud is blocking the flow thru the filter causing the loss in hydraulic power. Is that thinking correct?
/ 3215 HST #2
The first filter change is at 50 hrs. Check you owner manual maintinance schedule.
/ 3215 HST
Dang! How did I miss that!? I'll change the fluid AND the filters ASAP! Thanks. BTW, is the problem I described a classic example of the fix you offered? I feel like an idiot!
/ 3215 HST #4
I wouldn't guarantee that changing the fluid & filters is going to solve your problem, but I would start there.
/ 3215 HST #5
One other thing I would check quickly is...Make sure you don't have the 3 point hitch lower links binding up against the backhoe if you have the links on and raise them up they will hit the bottom of the backhoe creating a dead heading pressure which will make the tractor feel sluggish.
/ 3215 HST #6
Good thing Rick thought of that, as it is a very good possibility. I usually recommend when using the backhoe, take the 3PH arms off, because lifting them up against the backhoe is so easy to do without knowing.
2002 Chevrolet Express 3500 Shuttle Bus (A64194)
2002 Chevrolet...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A64194)
2014 International...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
7 foot bucket (A64194)
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
