Oil & Fuel 3215 filters at napa?
   / 3215 filters at napa? #1
Traymar73
Mahindra 3215
I am interested in getting filters for my 3215 shuttle shift from a local Napa, the only problem I have is the guys at Napa are not to motivated in helping find them. Does anyone have the napa numbers so I can save a long trip to the Mahindra dealer. I should just go somewhere else but it's only a stones throw to Napa.
   / 3215 filters at napa? #2
I can't directly answer your question but you can figure it out fairly easily. Go to the wix filters website (wixfilter.com) and punch in the Mahindra oil filter OEM number on their interchange lookup. It should give you the Wix number, drop the first number of the 5 digit part number and you have the Napa filter number. Alternatively, you may also be able to just look it up by model/engine on the same site.
Thanks I still have the boxes from the last service. Any idea about head light bulbs? They are $20 each from Mahindra.
   / 3215 filters at napa? #4
I have a Fram filter on mine, looked for reciept but couldn't fine, bringing tractor back to house today, so will look. I know that I started with Wix number and got filter at Napa :thumbsup: :D
Thanks for the help. Looks like may be putting it to work removing snow here in N E Oklahoma. So the next pm is just around the corner. With you guys helping out this one should be much cheaper.
   / 3215 filters at napa? #6
Myself, I'll spend the 25 dollars for a Mahindra oil filter to make sure that I'm getting the best filter for my engine as it sure beats having to repair the engine because I wanted to save a few dollars. The number of hours per year that I put on the tractor is less than the 100 hours the factory recommends to change it, but I change it and the oil twice a year once in the spring and later in the fall.
   / 3215 filters at napa? #7
My local NAPA guys were more than happy to open the book and find the NAPA filter for my 4110 ... it took the dude about 90 secs to find it.
   / 3215 filters at napa? #8
Filter 33264 fuel
Filter 51348 oil
Filter 51663 hydrolic
these are wix #'s, should be able to cross ref easily.
i have only been able to find the hydrostatic transmission filter at mahindra.
hope that helps
rob
Thanks very helpful!
   / 3215 filters at napa? #10
I thought the point in using NAPA filters was to finally replace that cheap made oem filter. :D
2020 Trailerman Trailer (A50514)
2020 Trailerman...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52128)
J and L Cargo...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2014 CATERPILLAR...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
