3204 goin slow
   / 3204 goin slow #1
jnovak01
Massachusetts
John Deere X749
I have a 3204 and have noticed that it can go about 60% as fast as it earlier in the year. Motor is strong and I checked the linkage between the forward/reverse pedal and adjusted it so it barely moves forward at idle.
when you depress the forward pedal it does go forward, but only at about 60%. I don't think it happened all at once, but even my wife noticed it as well, and I only let her on the Cub once or twice a year.
Any suggestions would be greatly appreciated.
Thanks
   / 3204 goin slow #2
Does it go faster backward? You have to balance the linkage adjustment - i.e. more forward speed means less backward speed. I have my 3235 adjusted so it just creeps backward, giving me the most forward speed I can get. It's still slower than my old 1450.
Bob B.
   / 3204 goin slow
Thanks for the tip, I will try that.
I actually had it so it would just go forward.
When I first bought it the dealer had it adjusted to where it would just go forward a little bit. Cub made it easy to adjust this withe the screw accessible thru the right wheel well.
Do you think chaning the fluid and filter would help?
   / 3204 goin slow #4
I wouldn't think so.
Bob B.
   / 3204 goin slow
I adjusted the mechanism so that it barely goes backward. The tractor goes at the same speed...about 60% as fast as it really should. I am thinking that perhaps it is the drive pump. Don't want to guess on these things, so I am just trying to check the obvious things. Checked the wheels, motor rpm - I don't have a tach, but the bagger is filling up well. Also the oil levels on both the enigne and the tranny are good.
For now I will keep looking, but no smoking guns as of yet.
   / 3204 goin slow #6
It could be the transmission fluid. If your transmission is like the 2500's, then break-in releases a lot of residue that changes the viscosity of the fluid. A filter change would be a quick and cheap way to check.
   / 3204 goin slow #7
This is a long shot but easy to test. I think the 3204 has a hydro release on the back of the rear end. This can get disengaged partially, the tractor I experieced that on was so slow in reverse it became unusable. The manual explains how to engage and disengage it, I think there is even a diagram next to the control.
Curt
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2014 Walker Compactor (A55787)
2014 Walker...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
