32 hp Mitsubishi Transmission problems will not move
   / 32 hp Mitsubishi Transmission problems will not move #1
itchypussy
Mitsubishi mt 3201
Mitsubishi MT3201 non hydraulic shuttle shift. Tractor will not move act's like trans main shaft is broken,but it's not. Clutch works PTO fine.
With tractor not running you can spin the starter and it will turn wheels . When motor is running it will not turn wheels.
   / 32 hp Mitsubishi Transmission problems will not move #2
I don't know much about the Mitsubishi, but it sounds like the transmission may be low on oil. I think those might use a torque converter and oil is absolutely necessary for it to work.
Not sure how your name got by the Moderators, but I'd see a doctor about it. o_O
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
