31x12.50-15 Turf tires for JD 855 4wd
   / 31x12.50-15 Turf tires for JD 855 4wd #1
aharvey
I need to replace the rear turf tires on my 855(4WD). I've contacted 4 tires stores in the area, 2 that specialize in truck tires, nobody has this size tire available with a turf tread. I checked TireRack online and they didn't have it either.
Does anyone know where I can find this size turf tire?
   / 31x12.50-15 Turf tires for JD 855 4wd #2
855 does NOT require 31x12.50-15 tires in back. Rear turfs are 33x12.50-15. And they are pretty darn hard to find. When you do, they are not cheap.
I've considered putting an all terrain light truck tire on mine. This year, I never bothered to take the R4's off for summer, only mounted the front turfs. Worked pretty well actually.
I was told by a JD dealer I had to keep the 31x12.50-15 size because the tractor is 4WD. So the front and rear tires sizes need to be paired so they will turn at the same speed when using the 4WD to keep prevent strain on the transmission/transfer case.
   / 31x12.50-15 Turf tires for JD 855 4wd #5
Might want to confirm your front tire size. If they are also smaller, then you do not want to move to a 33 in the back. If they are 23x8.50-12 then go with 33. Don't use the term Turf tires at a truck shop. Google 33x12.R15 using images and look for a tread you like. Likely an All season or Snow tire would be gentle on your lawn.
   / 31x12.50-15 Turf tires for JD 855 4wd #6
Thank you
   / 31x12.50-15 Turf tires for JD 855 4wd #7
Who does offer the correct size?
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
2019 CATERPILLAR 262D3 SKID STEER (A52705)
2019 CATERPILLAR...
Titan PDG3200 Gas Powered Post Driver (A52377)
Titan PDG3200 Gas...
