31x12.50-15 Turf tires for JD 855 4wd
   / 31x12.50-15 Turf tires for JD 855 4wd #1
aharvey
I need to replace the rear turf tires on my 855(4WD). I've contacted 4 tires stores in the area, 2 that specialize in truck tires, nobody has this size tire available with a turf tread. I checked TireRack online and they didn't have it either.
Does anyone know where I can find this size turf tire?
   / 31x12.50-15 Turf tires for JD 855 4wd #2
855 does NOT require 31x12.50-15 tires in back. Rear turfs are 33x12.50-15. And they are pretty darn hard to find. When you do, they are not cheap.
I've considered putting an all terrain light truck tire on mine. This year, I never bothered to take the R4's off for summer, only mounted the front turfs. Worked pretty well actually.
I was told by a JD dealer I had to keep the 31x12.50-15 size because the tractor is 4WD. So the front and rear tires sizes need to be paired so they will turn at the same speed when using the 4WD to keep prevent strain on the transmission/transfer case.
   / 31x12.50-15 Turf tires for JD 855 4wd #5
Might want to confirm your front tire size. If they are also smaller, then you do not want to move to a 33 in the back. If they are 23x8.50-12 then go with 33. Don't use the term Turf tires at a truck shop. Google 33x12.R15 using images and look for a tread you like. Likely an All season or Snow tire would be gentle on your lawn.
   / 31x12.50-15 Turf tires for JD 855 4wd #6
Thank you
   / 31x12.50-15 Turf tires for JD 855 4wd #7
Who does offer the correct size?
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
2013 RAM 4500 (A50323)
Engel 20' Boat (A50121)
Engel 20' Boat...
