318 rear axle
   / 318 rear axle #1
kenar
Jonesboro, AR
JD 318
Hi all, new to this forum, and tried serach option, but couldn't find an answer. I have just finished replacing the hydro pump and differential in my '90 model 318. Everything seemed fine...in the garage. I went out to mow and the right rear axle slid out about 1" or so causing the trat not to move. I discovered this after loading on my trainler and taking back to the garage. What did I miss? I re-used the old axle housings and removed them as a unit from each side when I replaced the power train. Any help is appreciated...
   / 318 rear axle
For those who read this and might be interested, the problem was the rear axle bearing.... completely trashed. I recovered 4 of the roller balls from the axle housing, no other damage, now back together and good as new!!!:thumbsup:
2004 INTERNATIONAL 4300 SBA 4X2 (A51406)
2004 INTERNATIONAL...
(2) DOUBLE AXLE FENDERS (A54756)
(2) DOUBLE AXLE...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
FORD 7710 TRACTOR (A54756)
FORD 7710 TRACTOR...
