318 Onan OVERSPEED.
/ 318 Onan OVERSPEED. #1
kketterer
John deere 111,318
Hi guys,
I have a deere 318, with the ONAN motor. I have been having an odd problem. The machine starts and idles perfectly, runs to WOT perfectly. However after several minutes of mowing, the engine begins to overspeed. I am able to bring the speed down with the throttle lever, however it's still too high.It will not "fix itself" until the engine cools down. It sounds like a very lean condition.
The carb has been flushed and cleaned. The fuel filter had been replaced.
What next? All intake gaskets, fuel Pump, fuel tank vent, Fuel Lines?
Any suggestions?
/ 318 Onan OVERSPEED. #2
Hi guys,
Any suggestions?
it sounds like the the governor is sticking.
+1:thumbsup:
The flyball spacer may have broken,or the cup and race on the camshaft may have excessive wear.
Greg
So it guess I should pull the motor and split the case to inspect that?
/ 318 Onan OVERSPEED. #5
kketterer,Welcome To TBN:)
There is no splitting the case,but you would have to take the fan shroud off,then the flywheel,then the governor housing cover,in order to inspect the governor. I would exhaust all other options before having to disassemble the engine though.
Greg
Greg
So I guess I would be looking for "other options" then.. Any suggestions?
/ 318 Onan OVERSPEED. #7
There are some very knowledgable people over at weekend freedom machines. If you're not familiar,go to the restoration and repair forum,then the hydrostaic drive tractor forum,then post your problem.
Greg
/ 318 Onan OVERSPEED. #8
Unfortunately this is a known and very common problem for these machines. The balls are in a plastic thing after you take the flywheel off. It fatiques, your motor overspeeds...
Wayne
Wayne
Hi Wayne, It will run all day long at 3/4 Throttle, But at full, It eventually overspeeds. I will look into the governer again. Thanks.
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
213087 (A64276)
213087 (A64276)
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
