318 Onan OVERSPEED.
/ 318 Onan OVERSPEED. #1
kketterer
John deere 111,318
Hi guys,
I have a deere 318, with the ONAN motor. I have been having an odd problem. The machine starts and idles perfectly, runs to WOT perfectly. However after several minutes of mowing, the engine begins to overspeed. I am able to bring the speed down with the throttle lever, however it's still too high.It will not "fix itself" until the engine cools down. It sounds like a very lean condition.
The carb has been flushed and cleaned. The fuel filter had been replaced.
What next? All intake gaskets, fuel Pump, fuel tank vent, Fuel Lines?
Any suggestions?
/ 318 Onan OVERSPEED. #2
Hi guys,
Any suggestions?
it sounds like the the governor is sticking.
+1:thumbsup:
The flyball spacer may have broken,or the cup and race on the camshaft may have excessive wear.
Greg
So it guess I should pull the motor and split the case to inspect that?
/ 318 Onan OVERSPEED. #5
kketterer,Welcome To TBN:)
There is no splitting the case,but you would have to take the fan shroud off,then the flywheel,then the governor housing cover,in order to inspect the governor. I would exhaust all other options before having to disassemble the engine though.
Greg
Greg
So I guess I would be looking for "other options" then.. Any suggestions?
/ 318 Onan OVERSPEED. #7
There are some very knowledgable people over at weekend freedom machines. If you're not familiar,go to the restoration and repair forum,then the hydrostaic drive tractor forum,then post your problem.
Greg
/ 318 Onan OVERSPEED. #8
Unfortunately this is a known and very common problem for these machines. The balls are in a plastic thing after you take the flywheel off. It fatiques, your motor overspeeds...
Wayne
Wayne
Hi Wayne, It will run all day long at 3/4 Throttle, But at full, It eventually overspeeds. I will look into the governer again. Thanks.
set of 4 tractor trailer tires Roadforce (A63118)
set of 4 tractor...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
