3130 Quick Attach Bucket
/ 3130 Quick Attach Bucket #1
Teabagger
Central New Jersey
Kubota KX-91 S & R520s
Hello, new user here. I just wanted to start by saying this is a great forum and I have found a lot of useful information from very helpful people. My brother and I have a medium sized landscaping company here in New Jersey. We have decided to upgrade from a 1987 Kubota L2250 to a brand new 3130 with 723 FEL and BH90. The only thing we cannot decide on is the quick attach bucket. It looks like a great idea for using different attachments such as forks and a plow pusher box. My question is how much does it take away from lifting capacity and break out force, and how far it it pushes the bucket away from the arms by adding this bracket. Any help would be appreciated. Thank You.
/ 3130 Quick Attach Bucket #2
Teabagger,
I have a L3130 DT with the QA. I really like it. The weight doesn't seem to affect the lifting power of the loader. I also have the heavy duty bucket and the bolt on cutting edge. Allot of weight out there in the steel alone, but I have lifted full buckets of dirt with no problems. I'm glad I have the QA setup. It is nice to drop that bucket when it's not needed like when brush hogging for example. Wish I had some other attachments for the front, but they will come with time. Good luck with your decision.
/ 3130 Quick Attach Bucket #3
I don't think you can go wrong with the Skid Steer QA option. It's better to buy it up front because if you decide you want it later you'll have to buy a new bucket also. I would also recommend R4 industrial tractors. The L3130 w/LA723 is a great tractor with lots of power but the standard AG tires are too narrow for the loads that the LA723 is capable of. Especially in the landscaping business where you'll probably be turning a lot. The R4's should wear better too. Hope this helps.
/ 3130 Quick Attach Bucket #4
The QA will indeed drop the loaders lift and curl ability as it pushes the bucket over 6" forward. I find the loader lift is decent but the curl a little weak. I came from a L48 and this may explain some of my reason for saying this. If you really think you will be adding forks etc., I would definitely get the QA. If you think there's only a remote chance, you could add it later and still save your bucket by welding on a QA bracket. My dealer does not recommend the QA if your attaching a 4N1 simply because the bucket is already so heavy and the QA diminishes the lift capacity further. The good thing is that the LA 723 is about the best loader when compared to the competition. It's incredible ease of removing is second to none. I remove/replace mine routinely. 30 seconds off about 2 minutes on. I would rather unload the loader then have it on if it's not needed. This was one of my main reasons for dropping down from the L48. I read about R4's vs R1's. I don't know if that was asked but the R1's will easily handle any loads this loader throws at them. I have R4's but that also had to do with my soil and the thicker more puncture resistance the stock R4's offer over the stock R1's. The L3130 looks like a great tractor. I have not tried the shuttle or DT but would think given the smaller engine that the DT would be a great option. I prefer HST and one reason I went with the slightly more HP L3830. Other then that, they are very similar. I cannot say enough great things about the L30 series. If your opting for the HST, the cruise control can actually be used as a hand control instead of the pedal. It allows for differential braking. Great tractors, great loader!
/ 3130 Quick Attach Bucket #5
I don't have that loader but have a Woods 1016, 72" bucket with QA. It lifts VERY FULL heaping buckets of damp, wet or muddy dirt, road gravel, 3/4", 1 1/2", 3" rock, no problem. Well almost no problem anyway, the box blade is hardly enough weight when I really fill the bucket. When digging the curl pops up anything I ask it too.
/ 3130 Quick Attach Bucket #6
Teabagger, I think your getting some good advice. There are some sharp L30 series owners here. The QA certainly offers a great deal of versatility to your tractor and I am very much in favor of that. If you think you will use it, or are even unsure, I'd opt for it. Rat...
/ 3130 Quick Attach Bucket #7
HI...
The 4 Kubota dealers I priced the L3130 at all recommend the QA feature on the 723 loader... ~$380...
R1 vs. R4 tires... if I recall correctly...
...the R4's have a much wider footprint... better weight dispersion...
...increase the overall rear width by about 1 foot... better stability on inclines...
cost several hundred more though...
Dave...
/ 3130 Quick Attach Bucket #8
The one area where I find the R4's less effective is in traction. If I'm sideways on a hill I slide down the hill much easier. It's a tradeoff and I opted for the R4's for the very reasons you mention. They are tougher and resist punctures better too. Your correct from my experience too, most dealers do price in the QA, I think it's a great addition for those who may or do swap loader implements.
/ 3130 Quick Attach Bucket #9
Teabagger:
I hope it's Lipton and not sleepytyme!!!
I have about the same setup as RaT, except I have the largest, 5030 with the cab. I have the LA 853 loader with the QA option. I agree, it's a good option. I don't notice any lack of curl ability but the breakout is a little weak. One thing about the QA is you might have to file off the corners of Bobcat attachments to allow the locking pins to fully seat. I have a set of IR-bobcat forks that I had to modify just slightly to all the pins to drop all the way down.
RaT is right on about the mount and dis-mount of the loaders. Kubota did away with the front mount as they had on previous years. 30 seconds, 2 pins and four couplers and you are free with no loader. The reverse attachment takes about 2 minutes, just like RaT says except for one thing. It's very important to dis-mount the loader on a level surface, preferrably concrete. Because it's just a 2 point mount, if the loader isn't exactly in the same plane as the uprights on the re-mount, the mounting pins will not fit. That can be a royal pain in the A**.
/ 3130 Quick Attach Bucket #10
I have the L3430 HSTcab and the LA723 with QA option and I find it excellent. I bought a Kasco snow plow to fit and it is on and off in 30 seconds. It is also nice to take off the FEL bucket when I am brush hogging.
Haz
/ 3130 Quick Attach Bucket #11
I don't know that on a day to day difference that the 100lbs or so differnce would ever be really noticed on a loader. The convience of it diefinitly will be.
/ 3130 Quick Attach Bucket #12
Art:
Actually, you will notice some difference, especially breakout force. The QA attachment moves the bucket farther forward of the pivot pin, reducing the leverage exerted by the hydraulic cylinders. All aspects of loader operation will be reduced somewhat, except for overall height. The most noticeable decreases will be in breakout and curl.
As Rat stated in a previous post (read previous post from Rat), the bucket is moved 6" farther forward. I have not actually measured it, I will take his measurement as fact. The QA option coupled with the 4 way control valve could make for some interesting combinations on the loader arms, like a power angling plow or a hydraulic post hole digger!!
/ 3130 Quick Attach Bucket #13
No question Art. I had debated on it and even though I did not get it, it had everything to do with not needing to change buckets or implements. I also figure that as handy as I am with welding, I could always purchase a bracket to attach to my exisitng non QA bucket. For most folks, I would certainly recommend it if they are even slightly interested in the ability to swap out loader implements. I saw a 4N1 on a L3130, it was a large 4N1 and with the QA, it certainly looked, and as the dealer mentioned probably not going to help the loaders lift ability by pushing the 4N1 another 6" or so out.
On the other hand, if you using the 4N1 for junk removal, I'd sacrifice smaller loads for the super convenince the 4N1 offers. Then, if you need to move a bunch of dirt for example, it's a snap to swap out the 4N1. The QA, a great idea.
