3130 - No High Range Forward
/ 3130 - No High Range Forward #1
5thGenTexan
Van Alstyne, Texas
Kubota Grand L3130
This morning I mowed a few spots I missed last time, then put the box blade and took off again. A bit later I tried to move a few piles of dirt with FEL and couldn't do much. I thought I was taking too big of a bite. It was then that I found that I could not go forward in any of the four gears when in high range. The throttle just increased the RPM, seemed as if it is stuck in neutral. Reverse works, low range seems to work in all four gears. I called the local Kubota dealer and the tech there thinks the neutral fork is broken. Does that sound right? I am gonna have em come pick it up next week, I'd just like to get a bit more insight into the problem.
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
INOP/NON-RUNING Genie GS3232 Scissor Lift (A65579)
INOP/NON-RUNING...
Pull Behind Sprayer (A65640)
Pull Behind...
2015 GMC Sierra Z71 (A62679)
2015 GMC Sierra...
