3120 or 3032E ??
   / 3120 or 3032E ?? #11
Ok, I think I am going with the 3120. Does anyone know the lifting capacity of the 330X and how does it compare to the 300CX ?
I just did a little digging and apparently both loaders are Quick-Park.
Quick on. Quick off.
Still, this info could stand corrected.
   / 3120 or 3032E ?? #13
Hi Dk, i've had a 3120 e hydro since Sept 2007 now got 820 hrs on clock - it's worked in a farm situation, its a very good tractor - comfortable, excellent vision when working. problems i've encountered...worst is that there is a plate on the very bottom of the front 4wd axle assembly. we've had rocks & logs come under the bucket & dent the plate 4 times in 3 years - hydo/oil fluid leaks out - the damned things r on the lowest part of the tractor & just not heavily enough material IMO- u have to be careful on that issue. steering adjustment slips sometimes - don't pull urself up one it if ur overweight like me:eek: have had the pedal sensor re-set on hydro ay 775 hrs - not a big job. other than that i'm very happy. i had a MF165 2 wd tractor that was 40 years old, spent nothing on it, but a lots changed and the 3120 with 4wd does all the old MF did & more.
re loader - one thing u have to watch is that the loader is stronger than the standard walled tyres that came on the unit. there r 2 3120 in our district, we both find when using the bucket we have to put lot of air in front tyres, then let some out when back to paddock work - both of us have blisters on the side walls of front tyres!!!! both of us have adopted the idea that we will let the tyre collapse & then replace with a thicker walled tyre at that time. i thought it was just me, was relieved when other owner had same issue. all that aside i find its a very good machine - it won't last out like MF165 did - not as heavy built, but neither will i - 10 years will see me off tractors anyways & each year i do less. if ur not going to do 1,000hrs a year i think u'll be happy. cant help more than that. cheers OzGH
   / 3120 or 3032E ??
I bought the 3120 today. It is my first hydro, I have had shuttle shift and geared trans in the past. I was please with the loader and how it handled overall. No looking back now. Thx to all !
   / 3120 or 3032E ?? #15
Congratulations. I think you'll be very pleased with your new machine.
On top of the FEL mast there is a 5/16" hole that does not seem to serve any purpose. Went to the local auto store and purchased two 5" convex mirrors that mount with a 3/8" threaded stud. Slipped a short piece of 3/8 ID clear tubing over the stud and inserted into 5/16" hole.
Presto - two adjustable rear view mirrors that so far don't seem to be stuck in the way.
   / 3120 or 3032E ?? #16
I'd like to see a picture of that tractor.:thumbsup:
Best of luck with the operation of your new machine.
   / 3120 or 3032E ?? #17
Good deal, for the extra $500 I think you made the better choice. WE WANT PICS>:D
   / 3120 or 3032E ?? #18
Yes, pics please and congrats to you on your new 3120 ! :thumbsup:
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
(INOP) CATERPILLAR PS-130 PNEUMATIC ROLLER (A51242)
(INOP) CATERPILLAR...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
