3110D Sensor lights
   / 3110D Sensor lights #1
goatpharmerx
Southeast Alabama
Yanmar 3110
My idiot lights *charge, oil, and temp* do not seem to be working is there a way to test them to see it is the bulb, sensor, or wiring is the culprit. On my old 240 I just bypassed and installed some generic guages from the auto parts store, but I would like to make them work on the 3110.
thanks
thanks
   / 3110D Sensor lights #3
Sounds like a fuse. That, 12 volts dc, and ground, is all they have in common.
   / 3110D Sensor lights #4
You were almost right I tracked it down to the fuse box. The fuse was good but the connection was a little rusty. I cleaned it up and now the oil and charge lights are working with the ignition on. The temp light still does not come on at startup. I had read some earlier post and tried testing it by grounding the wire out but nothing happened. The bulb is good b/c I swapped it over to one of the other working sockets. Any Suggestions?????
   / 3110D Sensor lights #7
Be sure you have a goood ground connection, both between the battery and the frame and the dash............other than that, could be bad contacts in the bulbholder, or a break inthe wire to the sender.............both fairly easy to check.
   / 3110D Sensor lights #8
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
JOHN DEERE 7210R LOT NUMBER 258 (A53084)
JOHN DEERE 7210R...
Pallet Fees (A50775)
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53472)
2016 Ford F350 -...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
