3110D front axle leak
   / 3110D front axle leak #1
goatpharmerx
Southeast Alabama
Yanmar 3110
My 3110D is leaking gear oil right behind both the left and right wheels. I'm not sure exactly which seal is bad but does anybody have any experience replacing the seals in this area.
   / 3110D front axle leak #2
i bet a picture would help give someone an idea of where the leak is and then to give some advice. Can you possibly post a pic?
   / 3110D front axle leak #3
I think I know where you are talking about but don't know the tech. term for that area. I have replaced that seal on my 3110D. It's on the lower part of the (hub?) that it turns when you turn the steering.If this is the area it's not a bad job.
   / 3110D front axle leak #4
That would be the kingpin seal. I've also had to replace this.
Eugene
   / 3110D front axle leak #5
There are 2 seals where the gear case goes into the gear box, check the gear case close for grooves in the case where the seal fits, if the grooves are too deep, the seals may not help.
Danny
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2021 Kubota SVL97-2 (A50123)
2021 Kubota...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
