3110 Hydraulic Service and other questions
   / 3110 Hydraulic Service and other questions #1
thunderheart
Mebane NC
YM3110
Hey fellas, couple of quick questions
1) When servicing the Hydraulics filter/screen/whatever-it-is, that is accessed at the back/bottom of the differential, is it required to drain the sump? Just wondering if the filter can be inspected outside of a fluid change. Looks to me as if you pull that thing, then all the fluid would come pouring out.
2) What size are the grease fittings on the 3110? I have a few that need replacing but figured I may as well do 'em all at once. They look like they are all the same size to me. I dropped by Northern Tool with one I had pulled off my lift arm but they didn't have them. Maybe Tractor Supply? There is a large JD dealer about 20 miles away as well.
3) One of the hydraulic lines on my tractor was cut at some point, under the right running-board. It's the larger of the two lines (return I think?) and I assume it was cut for an auxiliary unit like an FEL. Somebody patched it with a piece of rubber hose and some clamps :eek::confused2::thumbdown:. Could I just get a brass "T", flare the two ends of the cut, put in the "T" and the cap the spare outlet? Just as easy as a coupling but provides flexibility in future. My fluid level has dropped the last week when it had remain steady for the previous 40 hours or so. There has been a minor leak at the patch since I bought the tractor, but I have been using my new 6 ft, heavy framed disc harrow this week and I'm wondering if the added strain has made the leak worse. As part of my start of the year maintenance I want to go ahead and fix this patch.
Thanx for any advice,
Dallas
That thing is supposed to be on there !!??? Wow. Why? But yeah that is exactly what it looks like on my tractor Winston. However there is definitely a leak there on mine. Maybe it just needs to be replaced as the rubber looks cracked and kinda dry-rotted.
Thanx Brother!
   / 3110 Hydraulic Service and other questions #4
Yes, the rubber splice in the return line is factory. I had to replace my rubber hose there. If you don't drain the sump B-4 you remove the filter screen cover you will have fluid everywhere
   / 3110 Hydraulic Service and other questions #5
Humm mine is a solid line all the way from pump to the rear end guess I never noticed that until now.
   / 3110 Hydraulic Service and other questions #6
Well my return does have that rubber coupler after all for the record I looked but missed it earlier. I did my loader valve plumbing yesterday and had the right floor board out and there it is bigger than Dallas. :)
PALLET OF 1/4" X 2 DECKING SCREWS (A51247)
PALLET OF 1/4" X 2...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2023 JOHN DEERE 8R370 LOT IDENTIFIER 204 (A53084)
2023 JOHN DEERE...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2018 JOHN DEERE 317G SKID STEER (A51246)
2018 JOHN DEERE...
