3100 DH - price ?
   / 3100 DH - price ? #1
joan from zone 6
3100 DH - manual transmission - 4wd - 300 hours - little wear other than weathering - no attachments - ag tires - $8900 -
reasonable price or ......? thanks for the advice ! any comment on this particular model will also be a big help -
   / 3100 DH - price ? #2
Could you mean B7100DT?
   / 3100 DH - price ?
i'll have to check on that # tomorrow - i could swear i heard 3100 on the phone -
   / 3100 DH - price ?
you're right - wrong model #
now i'm told the hood decal reads "L3000DT" - but the details i listed were accurate - sorry for the mistake -
   / 3100 DH - price ? #8
Sounds like a fair deal to me. Here is a little information on that model. It appears to only been made from '02-'03 so it's still a really new tractor.
   / 3100 DH - price ? #9
Joan,
In terms of ground speed, the reverse gear on the 8x2 transmissions is normally between 2nd and 3rd gear for the Low reverse and between 6th and 7th gear for the High reverse. The High reverse will be almost too snappy to be useful; at least that's what I've found (L4300). The Low reverse is OK, but could be slower.
Normally you can regulate your reverse speed with throttle and it should be no problem....just idle the engine while backing. But if you are going to blow snow with a 3PH snow blower (requires operating in reverse with engine RPM set rather high) you'll find that even Low reverse is too fast. Hope that was clear.
Other than that one caveat, it should be a solid, simple and versatile tractor.
Bob
   / 3100 DH - price ?
many thanks for the info and for the advice - sorry about the original mix-up -
45051 (A51694)
45051 (A51694)
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
Toro ReelMaster Pull-Behind Hydraulic Reel Mower (A51691)
Toro ReelMaster...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
TMA (A49461)
TMA (A49461)
2021 KUBOTA SVL97-2 SKID STEER (A51246)
2021 KUBOTA...
