30x50x16 pole barn construction
   / 30x50x16 pole barn construction #1
747driver
Tellico Plains,TN
Kioti CK27 HST
Morton started on Friday ! 2 man crew for the foundation. That perma column system is great. So today I finished putting the stone around the grade boards. Easier to do it with no walls up. They will put the walls and trusses up come Monday . Nice to watch a crew do the work ! 20180727_102510.jpeg20180727_132548.jpeg20180727_141702.jpeg20180727_152858.jpeg20180728_182809.jpeg20180728_182901.jpeg20180728_182931.jpeg20180728_183046.jpeg20180720_093050.jpeg20180712_162110.jpeg
   / 30x50x16 pole barn construction #2
looks nice!.......keep showing the progress.........Jack
Morton Perma Column Installation - YouTube
First time posting a video from YouTube that I videoed. Hopefully it comes through. How do you get the video to come through without me having to post as a link ?
After all the columns are set and backfilled they come back and re-check all the heights and adjust if necessary. They don't fill the entire hole with concrete. Only the bottom 2' where there is rebar attached to the bottom of the column.
   / 30x50x16 pole barn construction #4
Put the word "video" in square brackets [] in front of the link. Repeat at the end but use "/video".
Should look something like this
[video=youtube;e3rwyf68hfc]https://www.youtube.com/watch?v=e3rwyf68
Thanks for the tip ! Thats what I was looking for.....
   / 30x50x16 pole barn construction #6
Interesting. Thanks for posting so many pics!!!
   / 30x50x16 pole barn construction #8
Lookin forward to your progress.
Day 2 and the walls are up snd trusses set. Only a 2 msn crew but those machines make all the difference. The trusses will get bolted when the roof is put down.20180730_103027.jpeg20180730_134615.jpeg20180730_180625.jpeg20180730_180907.jpeg20180730_181124.jpeg20180730_190517.jpeg20180730_134433.jpeg
Day 2 and the walls are up snd trusses set. Only a 2 msn crew but those machines make all the difference. The trusses will get bolted when the roof is put down.View attachment 565018View attachment 565019View attachment 565020View attachment 565021View attachment 565022View attachment 565023View attachment 565024
Day 3 got the vented soffits in, doors trimmed out. Protective liner panels should help in keeping things hitting the siding from the inside. Ready for the roof but it has rained the last 2 days.20180731_152409.jpeg20180731_152431.jpeg20180731_152513.jpeg20180731_152827.jpeg
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
