30hp Kioti and 14ft towing trailer ???
   / 30hp Kioti and 14ft towing trailer ??? #1
RMAL
I will be towing CK30 with fel and boxscraper.Local trailer dealer will make a great deel on a 9900 gvwr 14 ft double axle trailer. I think volume wise ,this may be too small??Are there any good trailers dealers in western NY?
Al
   / 30hp Kioti and 14ft towing trailer ??? #2
I believe you will have enough trailer. My first trailer was a 16ft 7500# gvwr. I loaded that with a Kioti lk3054, fel, tiller, grader blade and a 5ft mower. The mower was mounted on the tph and did hangover a little, but it towed fine.
I would be sure the trailer that he is quoting has brakes.
Good Luck with your new Kioti!
Jeff
   / 30hp Kioti and 14ft towing trailer ??? #3
</font><font color="blue" class="small">( I will be towing CK30 with fel and boxscraper.Local trailer dealer will make a great deel on a 9900 gvwr 14 ft double axle trailer.)</font>
Well, it depends on a few things, but I think you'll be sorry if you don't get at least 16' of trailer for that model. I have the CK20 and have used 12' and 16' with the 16' definitely being the ONE. Around here, it's cheaper to buy a 16' than a 14' as the 14' is not so common as 10',12',16' etc.
The CK30, with a loader, and a mower/backhoe/other implement hanging off the back would be much better on a 16' trailer. It can certainly be done with 14' but two feet makes a big difference in comfort level and ability to carry other implements along for the ride. John
   / 30hp Kioti and 14ft towing trailer ??? #4
Al,
Just a word of caution about trailer sizes.
Some vendors are counting the tongue when quoting the length.
Just be sure once you've decided, that you are getting what you are expecting.
Good luck.
-JC
   / 30hp Kioti and 14ft towing trailer ??? #5
I think 14ft of bed length is the absolute minimum. I used a trailer with a 12' bed, and had the bucket on the tongue, and with my box blade (TC24) it just fit. A rotary cutter would have been hanging off quite a bit.
Komatsu 330 Excavator (A51573)
Komatsu 330...
28013 (A50322)
28013 (A50322)
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
